Sun, Nov 17, 1:32 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Attaching light to a target
OberonRex ( ) posted Mon, 01 January 2024 at 11:12 AM · edited Thu, 07 November 2024 at 8:30 AM
I have code which creates a point source of light and attaches it to a prop named "target" which, in turn, is parented to another prop. It basically works fine except that the yTran for the new light is off by a bit.  yTran on the target is modified by a Master Parameter called BeamWidth, which seems related.
Here's where I get when I run my script, and you can see that the point light source is *not* centered on the dense ball ("target"). The light is created, parented to target, and then has all its coordinates set to zero. Everything is property aligned except for yTran.
I think that the problem is related to the use of a Master Parameter which is used to move target within a limited range. For this image, the parameters of target look like this: OCMVgtf6hYZ0nRchzEM66CZiPj7qsnTx8sLz5uzm.png. The yTran of the light is zero and needs to be .004 (!!) in order to be properly centered. No matter where I position the target and no matter how I scale target, the yTran of the light needs to be .004. I'm guessing that somehow I need to factor in the Master Parameter, but I have no clue how, nor do I understand why .004 is the magic number.
Any suggestions?
FVerbaas ( ) posted Mon, 01 January 2024 at 2:31 PM
Forum Coordinator
The origin of the ball mesh geometry may not be in the center of the ball.
In fact, the two are totally unrelated.
OberonRex ( ) posted Mon, 01 January 2024 at 2:50 PM
<a bulb goes on>
Thank you. That was probably exactly the insight I needed. I shall go futz with that and see where I get.
OberonRex ( ) posted Mon, 01 January 2024 at 2:55 PM
That's it!!! When I look at the parameters for the target, I see zyqcuMmIOz8NTIKueJpZldPBr2ZbWBY8Fvf3TK9i.png and there's my ,004. Now for some code adjustments. Thank you again!
