Wed, Nov 20, 7:56 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: What changes are needed to get this to work in Poser 12+ ?
3dcheapskate ( ) posted Fri, 12 January 2024 at 1:45 AM · edited Sun, 17 November 2024 at 10:37 AM
This is  a simple crappy cobbled together Poser 11 Python 2 script, one of four, from something I'm playing with over on the HiveWire3D forum here, post #66 - Towards better grass in Poser... | Page 4 | HiveWire 3D Community - and I'd like to get it working in Poser 12+ Python 3 too
1) Since I only have Poser 11 I can't test any changes I make to it
2) I don't really want to import compatibility libraries if I can do it without.
3) I know that I need to include brackets in my print "stuff" statements, thusly print ( "stuff" ) to get them to workin both Python 2 and 3
4) The try...except version stuff can go - that's a bit I forgot to delete from the source scrpt that I bashed about
5) Ideally I want one script that works in both Poser 11 and Poser 12+
P.S. Don't forget to put on your peril-sensitive sunglasses before looking at the 'code' ;o)
# RandomizeHexGeometries.py (Prototype 0.00)
# Test script for adding Ajax Easypose style ERC to a figure.
# 0.00:
import poser,random
# I put my scripts into a class simply to avoid possible conflict with stuff in the __main__ module.
class cheapskatesTemporaryClass(object):
def main(self):
# Get Poser version for doing version-specific stuff
poserversion = '0'
posermainversion = '0'
try:
self.poserversion = poser.AppVersion()
temp = self.poserversion.split('.')
self.posermainversion = temp[0]
except:
pass
# Abort if the user gets cold feet right at the start
confirmed = poser.DialogSimple.YesNo("This script randomizes hex geometries.\n\nDo you wish to continue?")
if not confirmed:
confirmed = poser.DialogSimple.YesNo("Do you want to see more information about what this script does?\n\n(This opens a debug window with extra information and terminates the script. You'll probably need to resize the debug window to read the information.)")
if confirmed:
# Briefly explain to the user what this script does and give an option toabort straight away
print "This script randomizes hex geometries... MORE EXPLANATION TO GO HERE"
return
# Abort if no figure selected
scn = poser.Scene()
curfig = scn.CurrentFigure()
curact = scn.CurrentActor()
if not curfig:
poser.DialogSimple.MessageBox("You need to have a figure selected for this script to do anything.\n\nScript aborted, no changes made.")
return
# Abort if the currently selected actor is NOT part of the figure (parented props are NOT part of the figure)
if not(curact.IsBodyPart() and curact.ItsFigure().Name()==curfig.Name()):
poser.DialogSimple.MessageBox("The selected actor is not an integral part of the selected figure.\n\nScript aborted, no changes made.")
return
# Let user select random grass or bump geometries
confirm1=poser.DialogSimple.YesNo("Set random geometry for each hex?")
if confirm1:
fromgrass = 1
tograss = 10
grassMenu = ["All grass (01-10)","Just old grass (01-05)","Just new grass (06-10)"]
sel = poser.DialogSimple.AskMenu('Subset only ?','Select subset range:',grassMenu)
if sel == grassMenu[0]:
fromgrass = 1
tograss = 5
elif sel == grassMenu[1]:
fromgrass = 1
tograss = 5
elif sel == grassMenu[2]:
fromgrass = 6
tograss = 10
# Reset the master geometry variant in the body
act = curfig.ActorByInternalName("BODY")
act.Parameter("Geometry Variant").SetValue(0)
print "Master geometry variant reset to 0"
# Randomize the geometry variants for each bone
i = 1
while i < 38:
if i < 10:
bone = "subhex0" + str(i)
else:
bone = "subhex" + str(i)
randgeom = random.randint(fromgrass,tograss)
print bone + " geometry set to " + str(randgeom)
act = curfig.ActorByInternalName(bone)
act.Parameter(bone+"_variants").SetValue(randgeom)
i = i + 1
# Redraw what we've modified
scn.Draw()
# Inform the user that it's all done
poser.DialogSimple.MessageBox("All done")
poser.DialogSimple.MessageBox("Running 3DCheapskates RandomizeHexGeometries.py script (prototype 0.00)\n\n(N.B. You should see a similar message when the script finishes. If you don't then the script has crashed!)")
cheapskatesTemporaryInstance = cheapskatesTemporaryClass()
cheapskatesTemporaryInstance.main()
poser.DialogSimple.MessageBox("3DCheapskates RandomizeHexGeometries.py script (prototype 0.00) all done.")
Footnote: code above cut-and-pasted from NotePad++ after changing EOLs to just LF. Also attempting to add RandomizeHexGeometries.txt to this post below
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
RAMWorks ( ) posted Fri, 12 January 2024 at 9:06 AM
Watching...
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
3dcheapskate ( ) posted Sat, 13 January 2024 at 5:40 AM
...and hoping ? ;o)
Y-Phil ( ) posted Sun, 14 January 2024 at 2:39 PM
I had to add two "try: except:" blocs, probably because I didn't used your script the right way, but as is, it works with Poser11 and Poser13
The key is the very first line, and indeed the use of print(...) even with Poser11.
from __future__ import print_function
# 0.00:
import poser,random
    def main(self):
        poserversion = '0'
        try:
        except:
            pass
        if not confirmed:
            if confirmed:
                print("This script randomizes hex geometries... MORE EXPLANATION TO GO HERE")
            return
        scn = poser.Scene()
        if not curfig:
            return
            return
        if confirm1:
            fromgrass = 1
            tograss = 10
                fromgrass = 1
                tograss = 5
                fromgrass = 1
                tograss = 5
                fromgrass = 6
                tograss = 10
            try:
            except:
                pass
            print("Master geometry variant reset to 0")
            i = 1
            while i < 38:
                if i < 10:
                else:
                print(bone + " geometry set to " + str(randgeom))
                try:
                except:
                    pass
                i = i + 1
        scn.Draw()
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil ( ) posted Sun, 14 January 2024 at 2:41 PM
Oh and just in case: I'm using Microsoft's Visual Studio Code, a free version exists for mac and linux as well, a simple copy-paste in the pages here does the trick.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
3dcheapskate ( ) posted Mon, 15 January 2024 at 6:22 AM · edited Mon, 15 January 2024 at 6:23 AM
Y-Phil posted at 2:39 PM Sun, 14 January 2024 - #4480368
...(clipped)...
Thanks, works fine in Poser 11 just as you said.
I'm curious about one thing though - to get my Freazypose to work in Poser 12 the only thing I had to do was add brackets to the prints - I didn't need to import the __future__ module. See ADPs two responses following my observation here. I'm fairly sure it's the same situation here.
3dcheapskate ( ) posted Mon, 15 January 2024 at 6:32 AM · edited Mon, 15 January 2024 at 6:32 AM
Y-Phil posted at 2:41 PM Sun, 14 January 2024 - #4480369
What EOL character does it use ? I recall having to use some bizarre EOL workaround to get cut-and-paste from NotePad++ to these forums to work. (And the alternative of attaching a text file still doesn't work)
I find that Notepad++ is more than sufficient for all my needs - the less MS stuff I have on my laptop the better, although I grudgingly permit Windows 10 :o)
3dcheapskate ( ) posted Mon, 15 January 2024 at 7:03 AM
Uploaded an updated set of the four scripts to post #77 of the HiveWire3D topic. Trying without importing the __future__ module, which after reading ADPs comments I don't think is necessary - these scripts are really simple. Also deleted the unnecessary Poser version try...except.
Y-Phil ( ) posted Mon, 15 January 2024 at 9:20 AM
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
