Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
works great now with the tweaks you showed me. thank you so much! (and thanks to phil-in-heaven for the original script, miss you!)
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
With many thanks to jancory for testing, instructions are below for those who want to make their own update:
Open the .py file in an editor (I use Notepad++) and:
- put brackets around the arguments of the print commands.
- in the includes at the top of the script change wx.lib.hyperlink to wx.lib.agw.hyperlink
- dlg.center no longer has a 'direction' keyword. For me it worked to leave that out, just call dlg.Center() without any arguments (line 382)
- fileDialog styles now have 'FD_' prepended to their names. wx.OPEN has become wx.FD_OPEN, etc. (line 380)
- strings have become different beasts and they are to be handled differently in binary write. I have no idea why Phil resorted to file writing, but the SaveLinesToFile method works after a revision as detailed in the below:
def SaveLinesToFile(lines, filepath):
fd = open(filepath, 'wb')
s = "\n".join(lines) #P13 Was: s=string.join(lines, '\n')
fd.write(str.encode(s)) #P13 encoded string for binary write
fd.close()
And: Some of Phil's scripts tried to write to the folder where the script is, and of course if you put it in the 'old' location under ProgramFiles that will not work because file writing is now protected.
I ran my version from an arbitrary folder and it worked. Best install under the 'new regime' of python files in library folders to prevent acces right errors.
https://www.renderosity.com/freestuff/items/69093/obj-importer-plus
is there a script like this anywhere for P13? primarily i'd like to import multiple props at one time.
-jan-
My Freebies
