Mon, Nov 25, 9:27 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2024 Nov 25 9:18 am)
Subject: Poser 13.3.680 is now available
tim ( ) posted Tue, 12 March 2024 at 5:04 PM · edited Mon, 25 November 2024 at 7:06 AM
Site Admin Online Now!
Details here: https://www.posersoftware.com/article/725/announcing-poser-133-release
Downloads here: https://www.posersoftware.com/downloads
With the minor version bump, free trials are enabled again for anyone that previously did trial on Poser 13.2.
hborre ( ) posted Tue, 12 March 2024 at 5:28 PM
Online Now!
Thank you.
ChromeStar ( ) posted Wed, 13 March 2024 at 5:51 PM
Since this is the last release of 13, it probably doesn't make sense for the release notes to still say "This is an Early Access release" but....
Poser 13.3.680 - 2024-03-08
- Talk Designer: Transcript correctly clears out previous supplemental text when loading a text file. #2323 (App), #472 (Beta)
- Talk Designer: Updated default Viseme mappings so all Cartoon Characters work. #2328 (App), #473 (Beta)
Poser 13.3.669 - 2024-02-29
- Fixed issue with Vicky 4 pmd not injecting external morphs. #2309 (App)
- On the Mac: fixed Crash when renaming a figure from the hierarchy panel. #2294 (App)
- Replaced current Lip Sync tech with Rhubarb Lip Sync. #2308 (App)
- Fixed 'Install from Zip Archive' to be case insensitive on .ZIP suffix. #2311 (App)
- Scenes sent to Render Queue correctly recognize the adaptive sampling setting. #2297 (App)
- Scenes with HSV node no longer ignored in Render Queue and Render in Background. #2292 (App)
- Normal maps correctly rendering when using PoserSurface root. #2276 (App)
- Replacing figures or props now gives warning message saving to the library when file compression/uncompression doesn't match. #2301 (App)
- Corrected Simple Color node so that it no longer creates invalid results in the cg shader code. #2286  (App)
- Corrected Joint center going into a confused state in the Joint Editor. #2318 (App)
