Sat, Jan 4, 5:27 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 04 2:41 pm)
Subject: where are morphing dials (curvy, etc) for LF2?
drawn ( ) posted Mon, 18 March 2024 at 4:51 PM · edited Thu, 02 January 2025 at 9:02 AM
I feel as if I've searched everywhere, altho I know I've seen and even used them once, but now cannot find?
need to re-organize my files
drawn
RedPhantom ( ) posted Mon, 18 March 2024 at 5:57 PM
Site Admin
Make sure you load the Pro version of LF2 and they will be there in the parameters dial. You might need to click on the little plus next to Body Shapes
RedPhantom ( ) posted Mon, 18 March 2024 at 5:59 PM
Site Admin
You've mentioned needing to organize your library in a few posts. You might want to do it now while it's small, unless you like long tedious tasks.
drawn ( ) posted Mon, 18 March 2024 at 7:27 PM
thanks, BUT it doesn't seem to work for me, this is the best I get, so far, and I know I've seen these controls before but now they don't seem to be there. is there something else I should do first?
I don't find the 3 bottom ones esp detail morphs faces and body shapes at all! where do they lurk?
drawn
drawn ( ) posted Mon, 18 March 2024 at 7:29 PM
"You've mentioned needing to organize your library in a few posts. You might want to do it now while it's small, unless you like long tedious tasks."
I hate them, I want everything ez. so I'll get started and probly ask a few questions.
d
hborre ( ) posted Mon, 18 March 2024 at 8:28 PM
If you own La Femme 2 pro, as RedPhantom mentioned, you should have those body shapes available.  There is the original La Femme 2 that comes with Poser that will not have those morph controls.  Now, if you have separately purchased the body and face morphs for La Femme 2 Pro, those morphs should be located in the Pose Category of the Library and must be injected into the figure.  But you have not indicated which morphs are absent and whether you own additional morph packs.
drawn ( ) posted Tue, 19 March 2024 at 12:07 AM · edited Tue, 19 March 2024 at 12:07 AM
I know I had morphs that made her curvy, voluptuous, pregnant, etc. and I don't see those anywhere. I've searched thru every prop category and no can see. something weird going on. I have these morphs not in props but in poses but that seems to be all
hborre ( ) posted Tue, 19 March 2024 at 7:46 AM · edited Tue, 19 March 2024 at 7:50 AM
The morphs belong in the Pose Category of the Library for easier access.  The LF2_BodyFX package contains 2 files, 1 to inject the morphs channels and the other to remove them.  Select the LF2 figure in your scene and apply the LF_BodyFX_INJ morphs.  The dials will appear in the Parameters/Properties Panel like every other morphing dial. You can save a figure with all the morphs back to the Library under the Figure Category so you don't need to inject them every time you need them. The only downside to doing that is the figure file size will get bigger and may unnecessarily bog down your system.
drawn ( ) posted Tue, 19 March 2024 at 10:02 AM
thanks for pointing me to the right items I used it and made her voluptuous and she popped out of her shorts and I tried to conform then again but no dice. so, is there a way to have my girl and make her hippier? Cloth room now? or ?
drawn
hborre ( ) posted Tue, 19 March 2024 at 11:27 AM
You need to copy the applied morphs from the Figure to the conforming shorts.  Select the shorts, go to Figure on the taskbar, and select 'Copy Morphs From...'; you need to copy the morphs you applied to figure to the shorts.
