Sat, Jan 25, 11:52 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Calling "Remove Detached Nodes" Wacro in a Script
Iuvenis_Scriptor ( ) posted Sat, 09 March 2024 at 12:11 AM · edited Mon, 20 January 2025 at 5:43 AM
I'm trying to write a script that moves around a few node connections and automatically deletes any nodes orphaned by the process.  I've located the script called by the "Remove Detached Nodes" wacro button, but so far, I haven't been able to get the programmatic call to have any effect.
My code looks like this:
for material in materials:
      //do some stuff that's not relevant here
      clear = poser.AppLocation()+"\Runtime\Python\poserScripts\Wacros\removeOrphans.py"
      (poser.Scene()).SelectMaterial(material)
      poser.ExecFile(clear)
If anyone has any guidance as to what I'm doing wrong, I would greatly appreciate it.  Thanks in advance!
EVargas ( ) posted Sat, 09 March 2024 at 8:38 AM
Hi, try escaping or inverting the slashes, I tested your lines "clear" and "poser.Exec" here and changing to this made the script run for me, with message "please select a material":
"\\Runtime\\Python\\poserScripts\\Wacros\\removeOrphans.py"
EVargas.Art
Iuvenis_Scriptor ( ) posted Tue, 19 March 2024 at 1:03 PM
Escaping did the trick.  Thanks!
