Wed, Jan 8, 8:23 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 08 6:33 am)
Subject: Can you tell me how I can fit it?
smalll ( ) posted Tue, 02 April 2024 at 5:54 AM · edited Wed, 08 January 2025 at 8:21 AM
Hi!
I'm studing making poser model.
https://drive.google.com/file/d/1tD-_hwxVQ2aOMvXO9lNOQ-7Vn54YF_QD/view?usp=sharing
As you can see hip has problem.
Please....
hborre ( ) posted Tue, 02 April 2024 at 4:26 PM
Online Now!
I believe you cannot share those files you are linking in your post, a violation of the EULA.  Unfortunately, DAZ Genesis 2 is no longer compatible with Poser 13 because conversion scripts are no longer working.  In addition, the model is 'broken' in multiple joint areas, making it impossible to work in Poser.  And applying poses that were not created initially for that specific model will not pose well.
primorge ( ) posted Tue, 02 April 2024 at 6:48 PM · edited Tue, 02 April 2024 at 6:48 PM
It's a tesselated genesis 2 model. The hip is grouped wrong also, a similar problem to the collar grouping that I pointed out in OP's other thread. There's a small strip of polys between the buttocks that should be grouped to the hip which causes both thighs to have touching groups. Most likely what's causing the splitting. The mesh obj is also unwelded at body part groups, which is of no consequence to the function of the cr2 in Poser but will be useless for using for sculpting FBM via imports elsewhere. The default state of the original Genesis 2 obj is of course quads and "unimesh"...
A8A18xsrP3o25IhvVrv2EtqyGy1WxLWR3r4B8tIf.png0SvzbUJXDC3NJ919svIiWL8LxJskJZ3oGHmxu9WC.png
Adding those polys to the hip will most likely fix the tearing. I took a look at the skeleton and it appears to be a good rig, I haven't looked at Genesis 2 in a long time but it appears to be the original rig.
I have some opinions about all of this but I'll keep that to myself.
Good luck.
smalll ( ) posted Wed, 03 April 2024 at 3:57 AM
Thank you.
Mr hborre, I deleted it.
smalll ( ) posted Wed, 03 April 2024 at 3:59 AM
Thank you.
Mr primorge , You gave me a great help.
