Tue, Nov 26, 6:43 PM CST
Subject: Locate Function Following Library Search
jjoyner ( ) posted Sun, 28 April 2024 at 3:09 PM · edited Tue, 26 November 2024 at 4:32 PM
Until last month, when I did a search in my Poser 11 Library, I could double click on a result and that would trigger the Locate feature to locate that folder or item in the applicable sub-library (figures, poses, etc.).  Now, that does not happen.  Does anyone know why?  Thanks.
RedPhantom ( ) posted Sun, 28 April 2024 at 3:54 PM
Site Admin
The double-click should either load the item or replace the item depending on your settings. To locate the item, right click on it.
jjoyner ( ) posted Sun, 28 April 2024 at 7:12 PM · edited Sun, 28 April 2024 at 7:12 PM
Double-clicking an item does load the item.  Double clicking a folder no longer locates the folder nor does selecting Locate after a right click on a folder or item locate it.
Y-Phil ( ) posted Mon, 29 April 2024 at 5:51 AM
I have completely stopped to double-click anything in this window because even in the 12 version: it's completely incoherent and I was always forgetting that double-clicking on a material setting, be it in the standard hierarchy or in the favorites part, it simply and always replace replace your current material.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
jjoyner ( ) posted Fri, 21 June 2024 at 2:31 PM · edited Fri, 21 June 2024 at 2:33 PM
I realize that double clicking an item loads it.  That is not the problem that I am facing.  When I double clicked a folder in the search results in the past, Poser 11 used to locate the folder in the Library.  When I right-click a folder or an item in the search results, Poser 11 pops up a menu to Locate the folder or item in the Library or to Show the folder in Explorer.  In the past, clicking one of those options executed the option.  Now, clicking one of those options does nothing.  Any ideas to get this extremely helpful feature working again? Thanks.
hborre ( ) posted Fri, 21 June 2024 at 3:48 PM
Are you running Poser 11 as administrator?  I had a situation where setting Poser to run as administrator prevented the app from performing any drag & drop from the browser.  Switching that off corrected the problem.
DeeceyArt ( ) posted Fri, 21 June 2024 at 5:35 PM · edited Fri, 21 June 2024 at 5:41 PM
You only have Figures selected to search through. It it that it might be a prop (Supervilla sounds like a prop rather than a figure is why I ask)?
jjoyner ( ) posted Fri, 21 June 2024 at 8:00 PM
hborre posted at 3:48 PM Fri, 21 June 2024 - #4486520
No, I'm not running as an Administrator.
jjoyner ( ) posted Fri, 21 June 2024 at 8:16 PM · edited Fri, 21 June 2024 at 8:18 PM
DeeceyArt posted at 5:35 PM Fri, 21 June 2024 - #4486527
Supervilla has four folders - figures, props, lights and materials.  For the sake of taking a simple screen capture, I restricted the search to just figures.  In the past, double-clicking on a folder took me to that folder in the Library. Clicking on Locate in the right-click context menu used to do the same thing as well.  No more though.
