(Last Updated: 2025 Jan 29 7:34 pm)
Create a new IK chain that's just the shoulder and the forearm in the goal. Enable that IK instead of the regular hand IK hands.
The manual covers creating IK chains here: https://www.posersoftware.com/documentation/13/index.htm#t=Poser_Reference_Manual%2FTools%2FEditors%2FCreating_IK_Chains.htm%23h&rhsearch=inverse%20kinematic
It's a drag n' drop operation. Click create chain in the Hierarchy Editor. Then, drag the chain pieces in order from beginning to goal. (Shoulder then forearm)
Another tool that you may find useful is the constraint groups. If you add a constraint to the IK goal you can use multiple constraints and turn them on and off during the animation. This has the affect of being able to change the IK goal in the middle of an animation.
Crash from parenting an IK goal ... that's worrying. If you can reproduce that please file a ticket in support with the steps you used.
Thank you so much! I found the documentation, but I was doing it wrong (I started adding the forearm which messed up the mesh).
Is this the right chapter on the constraint groups? I will dig through that. I will try to reproduce the crash and file a ticket.
Have an awesome day!
Yes that the stuff. These might be helpful too:
https://www.youtube.com/watch?v=8MD_DS0ZdGQ
https://www.youtube.com/watch?v=_vVajv4AhME
Hi,
I am a beginner trying to create a "simple" animation where I would like to have the Hand and Forearm locked in position while moving the hip up and down using IK.
Since the goal of the IK (default) is set to the Hand (the last item in the chain) the forearm keeps moving.
- I tried to remove the hand from the skeleton but it always deleted the figure.
- I tried to parent the hand to another body part which caused Poser to crash.
- I tried to animate it and remove the keyframes for arm and hand just resulting in weird movements.
I really would appreciate any hints on what I am doing wrong, or if it is even possible with Poser?
kind regards
Nina
