Forum Moderators: RedPhantom, Staff
New Poser Users Help F.A.Q (Last Updated: 2024 Jun 29 9:30 am)
Unfortunately, there is no guide like that. Asking here can help or trial and error. And remember for next time.
What issues are you having with navigating?
Until we know specifics, it's hard to help.
2 tips I can offer is to try turning on the Orbit select mode. It will make the camera rotate around a selected figure or prop rather than around the center of the scene.
It makes it easier to bring someone off to the side into better visibility
Also, try hiding things like walls if they are getting in the way of focusing on something in the scene.
Hide the ground for the top camera. The default ground is a dome so it will block everything. You might also need to hide the roof of the theater.
It doesn't look like you have the orbit selected turned on. Maybe you turned it off before doing your screen shot?
And if you've moved the camera around a lot, you might need to restore it Edit>Restore>Camera
Sometimes, to navigate in a scene with a lot of stuff, I find easier to select a part of a body and to orbit + zoom in/out from there.
Selecting a full body create larger movements, not always centered. Selecting a hip/head will force the cam to turn around it ( activate the orbit mode, else you'll have a kind of inversed effect.)
The shortcuts I use the most:
- space key + left button: pan
- alt key pressed + mouse's left button = orbit around the selected object
- ctrl + space keys pressed + mouse's left button = zoom in/out
With the last tip: by alternatively pressing / relaxing only the Ctrl key, you may rapidly position your cam.
PhYl.
Win10 on i7 8700K@4.3Ghz, 64Gb, Asus TUF Gaming RTX 4070 OC Edition, 2x 2Tb ssd + 6+4Tb hd + 1x 8Tb hd + 1 10T NAS, Poser 11, Poser 12 and now Poser 13
finally got the full school theater.pz3 prop open. looks great as far as I can tell, because I have not mastered the right techniques to move around and see different areas. been working on it 3 hours and no difference except I've learned a lot of things not to do. is that the only way to learn an older, complex prop or is there somewhere a simplistic guide for poser idiots?
woebegone drawn,
