Sat, Jan 18, 7:17 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 12 6:19 am)
banner
Subject: Redefine Origin of Prop?
OberonRex ( ) posted Sat, 01 June 2024 at 8:27 AM · edited Sat, 18 January 2025 at 6:57 AM
So I've created this cool temple prop, but when I drop it onto a scene or zero out its coordinates, it's way off from the center of the scene. And Control-D drops it a bit below ground level as well.
Can someone tell me how to redefine the origin such that it defaults to the center of ground for X and Z, and sitting on the ground properly for Y? I'm guessing it's simple -- if only I could figure it out!
RedPhantom ( ) posted Sat, 01 June 2024 at 9:49 AM
Site Admin
Try importing it with the center and place on floor checked
OberonRex ( ) posted Sat, 01 June 2024 at 10:26 AM
Hmm. I tried that but it has a zillion sub-pieces which suddenly become unavailble in the hierarchy window. They show up in the Materials room, just not in the Hierarchy window.
infinity10 ( ) posted Sat, 01 June 2024 at 12:17 PM · edited Sat, 01 June 2024 at 12:19 PM
OberonRex posted at 10:26 AM Sat, 1 June 2024 - #4485531
If you need the multiple hierachical parts for re-configuration in your scene, then we need to solve that problem, but if not, it's easier to work with just the one part.
As for getting it to zero location, can you try using Joint Editor on the base of the hierachy of parts.  Make the green and the red markers coincide in 3D space (ie, check front, top and side views for matching).  Move the prop to the centre of your scene. Save as a prop in Poser Library.  Start a new scene.  Load your saved prop from Poser Library.  Check how it appears.
Eternal Hobbyist
OberonRex ( ) posted Sun, 02 June 2024 at 7:15 AM
Ah. Thank you so much for all that! I shall have to play with the Joint Editor. I had suspected it would be the answer but could not figure it out. Meanwhile, it also turns out that taking the prop into the Setup Room and turning it into a Figure *also* has the side effect of somehow resetting the origin as wish, with all the subparts showing up properly as belonging to the Figure. However, I'd rather have it be a simple prop, not a figure, so I'll definitely try playing around with the Joint Editor.
Thank you again.
nerd ( ) posted Sun, 02 June 2024 at 5:59 PM
Forum Moderator
Actually there's a low effort way to zero the prop.
1) Import the prop to Poser
2) Manually position it where you want it to be when it's zeroed. You can scale it too
3) File > Export > OBJ ... Then select the object you want to export
4) On export options check "Include existing groups" and "Preserve existing material names". Uncheck all other options.
5) Save the new OBJ
6) New scene
7) Import the OBJ you just created
That's all. OBJ is not zeroed where you want it to be. The same trick can be used to fix scale and orientation too.
OberonRex ( ) posted Mon, 03 June 2024 at 7:27 AM
Thank you, nerd. I shall try that!
