Mon, Jan 6, 2:44 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 06 3:18 am)
Subject: buttons don't work?
drawn ( ) posted Fri, 05 July 2024 at 5:19 PM · edited Mon, 06 January 2025 at 2:36 PM
I'm trying to do a sequence of poses and in order to move from one to the next, I thought I can use the Memory Dots, but that doesn't work with this test. what can I do to make it work?
8hGbrEMwKuQqWSftFlQNp79ALjw5vLfvyZE1suPz.pngthe first pose, but then I selected a second pose...and when I try to move from one to next..
which is supposed to be one close to this: m8EeGYVomPyd2MZ4rcfh2tiNpqksxkE5d3BIv5BT.pngit just tears her bra off..
hborre ( ) posted Fri, 05 July 2024 at 5:41 PM
Online Now!
What type of clothing are you using for the model?  I am guessing dynamic clothing unless you forget to conform the clothing to her.  But you are not providing enough information about your specific problem.  Sequential poses require animation over a set number of frames and time.  Memory dots are not intended to be used in that manner.
nerd ( ) posted Fri, 05 July 2024 at 6:46 PM
Forum Moderator
Looks like the Pose Dot was applied to the clothes instead of the character. Make sure the character is selected before applying the Dot.
If you do make that mistake select the clothing then from the top menu choose Edit > Restore > Figure
drawn ( ) posted Sat, 06 July 2024 at 12:10 PM
YES! I made sure "she" was selected and then buttons allowed me to change her poses, so it works the waY I need.
drawn
