Forum Moderators: Kalypso, JacquelineJ
(Last Updated: 2024 Oct 04 7:38 pm)
I was able to shorten that part. Use the x scale to shorten it
If that doesn't work, make sure it isn't locked. The easiest way to check that is if you can make any changes to it (bend, twist, side-side) then it's not locked.
If it is frozen, go to objects>lock objects and uncheck
to me, the thumb on my LF2 character is too long. I tried shortening part of it, the part 2, below the first joint, but nothing happened. is it or just my perception? if it is, how can I change it?
drawn
