Wed, Jan 15, 8:45 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 14 7:52 am)
Subject: List file and collect scene inventory not showing model/geometry locations
Uncanny_Film ( ) posted Fri, 26 July 2024 at 9:05 AM · edited Wed, 15 January 2025 at 8:36 AM
Hi,
Are you the list files and collect seen inventory. Using posers built-in Scripts.
But as you can see in the screenshot. It's not showing me the model's location. I have like seven props/Model in the scene. But it's not showing up in the list at all under geometry.
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
RedPhantom ( ) posted Fri, 26 July 2024 at 10:59 AM
Site Admin
Some props don't have obj files associated with them. The geometry is embedded in the prop file. It's likely that's the case. If you open the pp2 file in a txt editor and you see something like this the geometry is embedded.
If you need the obj, you'll need to export it from a scene or use a geometry stripper to extract the geometry.
Uncanny_Film ( ) posted Fri, 26 July 2024 at 12:57 PM
RedPhantom posted at 10:59 AM Fri, 26 July 2024 - #4487762
Thanks for the reply. But all the props are imported obj files.
RedPhantom ( ) posted Fri, 26 July 2024 at 1:55 PM
Site Admin
Because they were imported vs loaded from a prop, it's treating them like embedded geometry
