There is no extra plugin installer, the plugins are part of the normal full installer that you download.
I assume that your Unreal is too new. Here the line from the system requirement in the FAQs from the e-on download page:
wabe posted at 1:04 AM Thu, 29 August 2024 - #4488867
Good morning,There is no extra plugin installer, the plugins are part of the normal full installer that you download.
- Unreal Engine 4.26-4.27 & 5.0.-5.1 (5.2 & 5.3 are supported by PlantFactory 2024)
I am on UE v5.3 but the plugins are not present.
Yes, I had installed Plant Factory 2024, but during the installation process there is no option to select the plugin, also, I had checked the Plant Factory installation folder under applications and just the Cinema 4D plugin is available.Did you install the 2023 or 2024 versions of Vue and Plant Factory? You need the 2024 version for Unreal 5.3
DREAMFORGE75 posted at 5:16 PM Thu, 29 August 2024 - #4488889
RHaseltine posted at 2:48 PM Thu, 29 August 2024 - #4488885You mean, during the installation process, after you have selected "new installation" earlier, you do not see this window?Yes, I had installed Plant Factory 2024, but during the installation process there is no option to select the plugin, also, I had checked the Plant Factory installation folder under applications and just the Cinema 4D plugin is available.Did you install the 2023 or 2024 versions of Vue and Plant Factory? You need the 2024 version for Unreal 5.3
wabe posted at 3:02 AM Fri, 30 August 2024 - #4488904
This is the only option available during installation, I had tried installing several times, cleaned install deleting previous installations but the Unreal Engine is not available, is there a way to download just en UE plugin or if someone is able to share the plugin?.
Thanks in advance.
DREAMFORGE75 posted at 10:08 AM Fri, 30 August 2024 - #4488911
Thanks in advance.
Sorry for the mistake, I had sent the wrong screen capture, with VUE and VUE Plant Factory I have the same issue, no UE plugin.
wabe posted at 1:19 AM Sat, 31 August 2024 - #4488938I have now an answer from an ex developer. It is indeed a Mac thing, the Unreal plugins never were developed for Mac - a glitch in the FAQs requirement section. It needs to be corrected.I greatly appreciate your time and help. Thanks.I think this is a Mac thing but will try to find out more.
Hello,
I just downloaded the latest version of VUE, Plant Factory, and Catalog for Mac OS arm, I went through the installation and folders but I was not able to find the plugin for Unreal Engine 5, can someone please provide information and links to download the plugins?.
Thanks in advance for the assistance.
