(Last Updated: 2025 Jan 03 9:11 am)
Even in preview they should not show in a render when hidden.
Did you turn off the control props in the body of the figure? Any commercial figure will have a control to show or hide all the body handles.
If you've made new handles they will need to be setup to be controlled by a master dial in the body like commercial content. (That's subject for a tutorial.)
Or, you can manually hide a body handle. You can't click a body handle to select it. You have to pick it from the actor list in the "Actor" list.
Then uncheck "Visible" object's properties tab.
If you need to set up a newly created body handle let me know that's a bit deep for a forum thread. I'll need to do a tutorial on how to set those up.
I'm trying to do renders & the pose control chips are always visible even if they're turned off. What am i doing wrong?
Guardian_Angel_671
Daz Studio Coordinator
May the hands of fate be kind to you and yours. :)
guardian_angel_671@renderosity.com
