Sat, Feb 1, 9:03 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 6:51 am)
Subject: figure Cookie into poser 13 and I can't see it in my workspace
monique1966 ( ) posted Thu, 14 November 2024 at 9:14 AM · edited Sat, 01 February 2025 at 8:54 AM
I load a figure Cookie into poser 13 and I can't see it in my workspace.
It did work, I reset the factory settings so I get that Andy again,
but this didn't work either, maybe there is just a check mark somewhere not good
but I can't find it please help me.
Greetings Monique
DeeceyArt ( ) posted Thu, 14 November 2024 at 10:48 AM
How are you loading Cookie?  I'm assuming she is included in your DAZ content folder.  More info would help us answer your question.
Do you also have that same Content folder added to Poser as an external library?
hborre ( ) posted Thu, 14 November 2024 at 12:36 PM
According to DAZ, Cookie is a Poser item because there is only 1 Poser Core installer listed on the webpage.  Unless the runtime was removed or relocated, it should work.
monique1966 ( ) posted Fri, 15 November 2024 at 4:06 AM
I work with Poser 13.
I have been working with Poser for more than 10 years, but I have never experienced this and I cannot find the solution either.
I have also reset everything to factory settings and restarted but still no results.
I load my cookie via the runtime folder, not via the content.
I don't work with DAZ, it's really about Poser 13.
bwldrd ( ) posted Fri, 15 November 2024 at 8:01 AM
Does it show the figure as being loaded, just not visible?  if so, may have corrupted geometry.   Had this happen couple times with V4, don't know how it corrupted, but reinstalling/replacing the geometry fixed it for me.
Consider me insane if you wish, but is your reality any better?
DeeceyArt ( ) posted Fri, 15 November 2024 at 9:11 AM · edited Fri, 15 November 2024 at 9:11 AM
Would it be possible for you to share a screenshot of where Cookie appears in your library runtime folder?
randym77 ( ) posted Sun, 17 November 2024 at 12:50 AM
It should work. I just tried downloading Cookie from DAZ and using her in Poser 13, and it worked as expected.
What happens if you render? Can you see her then?
Anim8dtoon ( ) posted Mon, 18 November 2024 at 10:25 PM
Forum Moderator
It could be that you inadvertently pulled down the Figure menu and clicked on the 'Hide Figure', in which case she wouldn't be visible in the scene. Pulling that menu down and navigating to 'Show all figures' should make her visible again.
