Blender F.A.Q (Last Updated: 2025 Jan 19 8:07 pm)
That panel is no longer there the last button is the add cube button and the other button have replace what use to be panel of 2.73 so all the transformation were made into buttons instead
Lobo3433
atpo posted at 9:55 PM Thu, 9 January 2025 - #4492720
If you hit "N" it will bring up options on the right of the 3d viewport, the item tab should let you change the properties.Thanks.
"That panel is no longer there", but how to change cube radius then?
Or when you first put the cube in the scene, you can set most of the properties with the pop up dialog at the lower left.
Are you really still using Blender 2.xx? Version 4.3 is available.
______________________________________________________________
Everything important in life I've learned from somebody else's forum signature.
Excuse me!
Where is same panel "add cube" in blender 2.43?
I find it is 2.76,but didn't find it in blender 2.43.
Thanks.
