Sun, Feb 2, 10:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Losing Textures from Poser Pro Pack to 3D Studio Max
jaybutton ( ) posted Sun, 04 November 2001 at 11:13 PM ยท edited Sun, 02 February 2025 at 9:58 PM
Still a newby to all this. When I "host" Poser .pz3's in Max they lose their assigned textures. Am I doing something wrong or do I need to go get the textures out of my Poser files? Thanks in advance! Jay
aleks ( ) posted Mon, 05 November 2001 at 3:19 AM
are they not there even after the rendering (because sometimes they don't show in max window)? if so it could be poser issue - try 4.03 fix.
jaybutton ( ) posted Mon, 05 November 2001 at 9:22 AM
Thanks for replying, aleks. I had the same thought and tried rendering, still no texture. As for 4.03, I already have it loaded. I still in the dark about this if anybody can help. I load a character in Poser and add a texture, but when I host it in Max, the texture is gone. Anybody else having this problem? Thanks! Jay
aleks ( ) posted Mon, 05 November 2001 at 11:00 AM
ok, when you pick up the texture from the selected object, it should be a multi-map texture. can you see it? do you have bitmaps assigned to the map slots?
rodzilla ( ) posted Mon, 05 November 2001 at 12:43 PM
just to clarify what aleks said...host your scene in max,it'll come in with no textures initially.open your material editor look for and then click on the "get material" button,then when that window opens choose to get your materials from "scene"......and there they are,assign them to a slot and then whatever poser object they belong too.you'll still probably have to go through each bitmap in the multi-map to click the "visable in viewport" button to see em in the viewports,tho once assigned they will show up in your renders
jaybutton ( ) posted Tue, 06 November 2001 at 11:17 PM
Thanks guys for the tips. I have been really busy the couple of days, but I will post again when I have had a chance to try your suggestion. Jay
jaybutton ( ) posted Wed, 07 November 2001 at 9:30 PM
Well, I had a chance to play with it and was able to solve the problem. Pack, from the Max forum, reccomended that I upgrade to PPP Service Release 3. That did it. The textures are now importing with the models and rendering. Thanks for your help! Jay
