Wed, Feb 26, 2:00 PM CST
Forum Moderators: RedPhantom
Subject: Vicky 2 P4 Morphs
Kaylic ( ) posted Tue, 06 November 2001 at 2:45 AM ยท edited Wed, 26 February 2025 at 1:40 PM
Is there a way to add morphs to the V2 model that has the P4 proportions? Iv'e tried adding both Vic and posette morphs, but I haven't got either of them to work.
Jaager ( ) posted Tue, 06 November 2001 at 4:16 AM
Head morphs work. The geometry is its own. Morphs must be done from scratch. This figure is about clothing. Any body morphs would also require similar clothing morphs. If you are going to do a nude or semi nude figure, you use Vic. So, there is really no point in doing the morphs
egaeus ( ) posted Tue, 06 November 2001 at 6:20 AM
Actually the head morphs don't necessariy work well if you're cross-morphing between Vic 2 and P4 Vic. If you make a whole head morph on Vic and apply it to P4, P4's neck stretches. If you reverse the process, create a head morph with P4 Vic and use it on Vic 2, the head smashes down on her neck. You have to use face poses for it to work correctly. Mike
Jaager ( ) posted Tue, 06 November 2001 at 1:09 PM
You use MM4 and copy the morphs - cr2 to cr2. Appling the morphs in Poser involves location as well as the usual morph information. V2P4 is shorter than V2 - (P4 is shorter than V2). Copying the morphs involves only the differences and not where the group was in Poser when the morph was exported or applied. All V2 morphs will copy to the Mil Kids the same way. Because of the heavy morphing, the morphs often do strange things, but you can try them and discard the ones that are inappropriate.
Kaylic ( ) posted Tue, 06 November 2001 at 11:27 PM
Thanks for the responses. At least I can stop pulling my hair out trying to figure out a way to do it. The main reason I wanted to add morphs was because I have 5 times as many posette clothes and a couple of them ( well..ok most of them ) are a bit on the not so modest side and the V2P4 morphs are crap ( except for the face ).
Well I guess now I have a good excuse to learn how to use magnets.
