Sun, Nov 24, 2:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 1:33 pm)
Subject: has anyone seen this problem? broken mesh
darhorn ( ) posted Tue, 06 November 2001 at 9:05 AM ยท edited Sun, 04 August 2024 at 8:17 AM
Attached Link: Darrins Den
this is voluptous vicki and there seems to be some areas of the neck which are broken, I dont remember that this happened before, but I havent used her for a little bit... any solutions? thanks Darrin
mithrandir2K ( ) posted Tue, 06 November 2001 at 9:53 AM
try deleting the corresponding rsr file and then reloading the figure. This will force Poser to create a new rsr and seems to fix these periodic glitches. Hope this helps. Regards, Mithrandir2K
darhorn ( ) posted Tue, 06 November 2001 at 10:58 AM
thanks! will try it when I get home.... Darrin
JeffH ( ) posted Tue, 06 November 2001 at 11:00 AM
If you're using the Pro Pack, make sure you have the update installed.
darhorn ( ) posted Tue, 06 November 2001 at 11:26 AM
I dont have the update yet.... will it cause problems if I delete the rsr first? Darrin
HandspanStudios ( ) posted Tue, 06 November 2001 at 8:42 PM
Actually it's a bug that happens in pro pack when the grouping tool has been used. At least i had that same thing show up on other vickies for that reason. Maybe the update fixes that?
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
