Fri, Nov 22, 10:41 AM CST
Subject: How do I alter the colour of a mat pose file?
chohole ( ) posted Wed, 07 November 2001 at 1:25 PM · edited Thu, 01 August 2024 at 1:58 PM
In this instance I am using Maiden hair by Vairesh, and no one seems to have made any alternative textures for it. I need it to be platinum blond. Help please
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
nyar1ath0tep ( ) posted Wed, 07 November 2001 at 1:45 PM
You can try these methods:
  • Edit the MAT file to change the RGB value of the hair (if applicable; assumes the MAT file has some base color other than white, through which the existing texture is multiplying)
  • Edit the MAT file to change the textureMap path to a platinum blonde texture file, then resave under a different MAT file name
  • Rename your platinum blonde texture file to be the same as the existing file (first resave the existing file under a new name)
  • Convert the existing texture file to platinum blonde by desaturating or lightening somehow (probably not a good idea)
bloodsong ( ) posted Wed, 07 November 2001 at 2:40 PM
heyas; there's a mat pose editor in the free stuff by scourge that will change colours, and maps. (but not the higlight size or trans things.) but it sounds to me as if you need new textures, not new mat poses. try editing the texture that comes with it to make it the new colour (in a 2d program). if you have a blonde texture already, you might also try messing with the base object colour. use the poser render:materials settings, not mat poses, to change this.
