Thu, Dec 26, 8:20 AM CST
Subject: Roaming textures
Alcofuel ( ) posted Fri, 09 November 2001 at 9:21 AM · edited Fri, 09 August 2024 at 11:13 PM
Is there a way to 'lock' a texture to an object? For example, i've made a tubular shaped spaceship & i have a Grid like bump map texture on it but when i move it around the texture appears to have moved round the object & not with it.
hogwardenwork ( ) posted Fri, 09 November 2001 at 10:02 AM
Do you have the texture set to "World Space"? Try using "Object Space" and see if that works.
EricofSD ( ) posted Fri, 09 November 2001 at 11:03 PM
Once set to object space, you may need to play with the editor and rotate the texture.
Alcofuel ( ) posted Sat, 10 November 2001 at 4:27 AM
Nice one, sorted.
