Sat, Jan 11, 4:24 PM CST
Subject: Prop Problem...
DarkEden ( ) posted Sat, 10 November 2001 at 2:47 PM ยท edited Mon, 23 December 2024 at 8:47 PM
I have a problem... I have downloaded a Lightsabre thats a 3ds object and when i import it, it becomes a prop. What i don't know is how can i setparent a prop to a hand or so? And does anyone know where i can get hold of Poser ready Starwars stuff... Not just the droids that are on Renderosity... What i want is a poser ready Lightsabre.... //DrakEden
bloodsong ( ) posted Sat, 10 November 2001 at 7:39 PM
heyas; select your lightsaber and move it so it is in the figure's hand. then use object properties (or ctrl-i) to set the parent. select the hand (right or left, whichever you put it in) from the hierarchy. you should then save the prop to the props library. when it says 'this prop has a parent, do you want to make it a smart prop?' say yes. also, it is often handy to lock the prop after you parent it, so you don't accidentally grab it and move it. that is also under the object menu (no shortcut key).
DarkEden ( ) posted Sun, 11 November 2001 at 5:20 AM
Thanks Bloodsong!
