Sun, Nov 24, 7:59 AM CST
Subject: Problem conforming Victoria Gladiator breastplate
Gromit ( ) posted Sun, 11 November 2001 at 12:57 PM ยท edited Sun, 24 November 2024 at 5:57 AM
I just got the DAZ Victoria Gladiator outfit. When I try to conform the breastplate to Victoria 2, her boobs hang out. I can't see anything that I'm doing wrong, she is in the default position with no changes of any kind before I conform the breastplate. Anybody know what I'm doing wrong? Gromit
shadowcat ( ) posted Sun, 11 November 2001 at 2:56 PM
easy fix would be to shrink the boobs, they won't show anyway right?
Gromit ( ) posted Sun, 11 November 2001 at 11:22 PM
Yes, I guess that will work. I thought when I conformed the breastplate, it would map itself to the figure even if there was a scale change, etc.
shadowcat ( ) posted Sun, 11 November 2001 at 11:43 PM
If you scaled the person, you would need to do the same to any clothing. Conforming will only match the body parts and the position not sizing. For example it will put the sleeve over the arm and move it as the arm moves, but if the arm is to big it won't resize itself to fit.
Gromit ( ) posted Mon, 12 November 2001 at 12:14 AM
Seems to work ok. This is a quick test to see that it all fits.
shadowcat ( ) posted Mon, 12 November 2001 at 12:22 AM
looks good
jbrugion ( ) posted Mon, 12 November 2001 at 1:04 AM
Actually, the best solution is hit the "BrstNatural" dial a little bit. Pulls them down a little and under the armor.
