Thu, Feb 13, 2:27 PM CST
Subject: Network rendering
T-Macc ( ) posted Sat, 10 November 2001 at 2:17 AM · edited Thu, 13 February 2025 at 2:22 PM
I'm having a heck of a time getting the network renderer in Bryce 5 to work,........er, actually I can't get it to work at all. I'm running 3 machines; the server is a 1Ghz P3, running win 2000 pro, the client machines are as follows; a dual P3 500Mhz running Win NT Workstation 4.0 w/SP6 and an old P2 350 running Win 98. I have configured everything the way the manual instructs you to, but every time I go to use it, nothing happens on any machine, nothing at all. On the Win NT machine Bryce lithning won't even load; I get the splash screen and then an access violation dialog box, then it crashes. I have several other 3D apps on that machine, are there any known conflicts with Bryce lightning and other 3D apps ? Also, is it me or do the render times seem greatly increased in this version ? It seems the quality has gone up but so have the render times. This factor coupled with the network render problems makes this virtually unuseable for me. I do a fair amount of architechual walk-throughs using Bryce 4 and I can't imagine dealing with the increased time needed to use version 5 for the same work. I installed my upgrade after the Corel help lines had closed for the weekend but I will be on the phone first thing monday morning. Does anyone think I should uninstall and re-install ? I rendered a 40 mb scene in Bryce 4 on normal setting and the first pass time was 12 minutes the same scene rendered in Bryce 5 first pass time was 2 hours 18 minutes. What gives ?? Help ......TOM.
SevenOfEleven ( ) posted Tue, 13 November 2001 at 4:27 AM
Have you been able to fix your problem? Check your settings, I had overlong renderings untill I noticed that the gel setting in the lighting section was on.
T-Macc ( ) posted Tue, 13 November 2001 at 1:19 PM
No, I haven't,......I have a friend coming over to look at it today(the guy who built my machines and set up my network). Thanks for the tip about gel's, I'll check it out. T.M.McCann
dg3d ( ) posted Tue, 13 November 2001 at 2:13 PM
You should check the configuration of you network, i did sometest and if i check IPX/SPX on my network card, Bryce lighting do nothing, i take the check mark off and only check TCP/IP and then it start. Pleiades
