Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
I'm not 100% certain what you mean by this. Are you asking why the facial features do not match up to the features on the texture? If this is the case, then you must remember that the image is mapped onto the figure - in other words, just applied to the surface of the mesh. There's no actual modification of the mesh going on. If, on the other hand, you are saying that the texture isn't being applied to the face, then you need to check whether the base figure is P3 or P4 and that the texture you are applying is the right one. P4 figures use different UV mapping to P3 figures and the texture maps will not match up. Hope this helps :) Paul
hi everyone When I use some textures that download from here as the skin material of my model, why the face will not be changed like the face on the testure picture? Thanks a lot. Rino
