Tue, Nov 26, 3:08 AM CST
Subject: Java update messed up the Bryce 5 help!
seedpress ( ) posted Mon, 19 November 2001 at 9:40 PM · edited Fri, 09 August 2024 at 1:32 AM
I just installed the latest Java plug-in for Windows 98 and IE; now I get a runtime error when I try to run the Bryce 5 help files. Has anyone else had this problem? Any fixes?
seedpress ( ) posted Mon, 19 November 2001 at 11:24 PM
By the way: I've just re-installed the latest Sun Java plugin, and also re-installed the Bryse 5 help files (but have not re-installed the full B5 application. I'm still having the same problem. Beware of installing the new Java if you already have Bryce 5 installed.
seedpress ( ) posted Tue, 20 November 2001 at 2:36 PM
Some more about my Java/Bryce 5 help problem:
The Java works fine. So does Bryce 5--minus the help.
Here's what pops up when I try to run the help:
Java Plugin Exception dialog:
General Exception
Java.lang.ClassNotFoundException: java.io.FileNotFoundException: C:Program FilesCorelBryce 5HelpcomwebworkshelpWWHelp.class (The system cannot find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source)
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at sun.plugin.security.PluginClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
seedpress ( ) posted Tue, 20 November 2001 at 10:41 PM
Well I solved the problem--sort of: I uninstalled the latest Java (see other posts for details.) So , according to my program list, I have NO Java present. Yet now the Bryce 5 help files are working fine. Here's a quote from the Bryce 5 Readme.txt: "The Bryce online Help system requires that Java be enabled in your Web browser, or Help functionality may be impaired. Computers with newly installed Microsoft Windows 98 operating systems typically have Java disabled in their Web browser. Please consult the appropriate Help documentation included with the operating system to enable this. Your system must also have istalled the latest update for the Microsoft Virtual Machine ( Microsoft VM ) installed. This is easily done from IE using the menu item Help/Product Updates. The Microsoft Virtual Machine ( Microsoft VM ) is what you need to be able to see and interact with Java Applets." I think the latest Sun Java messed up the "Microsoft Virtual Machine." Uninstalling the latest Sun Java fixed things. On a parting note: It would be nice if the new Sun Java could co-exist with the Bryce 5 help files. But, my experience, at least, suggests that they can't. If anyone else has had this problem, and has figured out how to get them to "co-exist", please advise. Neither Sun nor Corel have offered any insight so far. . .
