Wed, Dec 11, 5:32 AM CST
Subject: trans maps for poser hair in bryce5?
ghst32 ( ) posted Fri, 23 November 2001 at 4:18 PM · edited Thu, 14 November 2024 at 1:36 AM
How do I get the transparency maps to work on the hair that was imported into bryce 5 from poser 4? I have gone into the pic source editor in bryce and selected the texture and then put the alpha channel transparent texture on it and the little preview window looks like it should work but then when I applie it and go out to my model nothing has changed.
ringbearer ( ) posted Fri, 23 November 2001 at 5:20 PM
Did you put a bead in the transparency channel? Also make sure you select blend transparency under the Material Options drop down menu.
There are a lot of things worse than dying, being afraid all the time would be one.
ghst32 ( ) posted Fri, 23 November 2001 at 5:27 PM
thanks that did it!
