Turn on the ik chains, you will see an set of 'end point' coordinates appear under some joint parameters that's not visible with ik off. Also I believe you need to use spherical falloff zones for that joint.
"Your work is to keep cranking the flywheel that turns the gears
that spin the belt in the engine of belief that keeps you and your
desk in midair."
Annie Dillard
