Mon, Feb 3, 11:07 AM CST
Subject: Victoria's Texture Settings
ronknights ( ) posted Tue, 27 November 2001 at 7:27 AM ยท edited Mon, 03 February 2025 at 11:02 AM
Attached Link: http://www.ronknights.com/victoria/
OK, I finally managed to put together a short tutorial showing Victoria's texture settings. If someone needs more background on how to do the settings, I have another tutorial listed for that information. You will note Victoria has no hair in this tutorial. That's the way she comes "out of the box!" I had some fun putting together the images for this tutorial. I hope you like it. By the way, what is a "lacrimal?!"
eirian ( ) posted Tue, 27 November 2001 at 8:04 AM
The tut looks good, Ron! A lacrimal is a tear duct (in other words, the inner corners of the eye). I had to look it up, too! Eirian
thgeisel ( ) posted Tue, 27 November 2001 at 8:09 AM
Hi ron,I think the teeth are normally on the bodymap, not on the headmap.
ronknights ( ) posted Tue, 27 November 2001 at 9:47 AM
I tell you these settings came from a MAT pose file I had... This is the natural look. (No makeup I guess). So I guess the teeth setting is right?! Thanks for the compliments.
thgeisel ( ) posted Tue, 27 November 2001 at 1:10 PM
maybe im wrong, so new to poser :-)))
Kelderek ( ) posted Wed, 28 November 2001 at 3:56 PM
thgeisel is correct, the teeth are on the body map.
ronknights ( ) posted Wed, 28 November 2001 at 9:22 PM
OK, so then the MAT File thing I used is wrong?!
Kelderek ( ) posted Thu, 29 November 2001 at 1:43 AM
Yes, ronknights, it appears so. The easiest thing to do is actually to look directly at any Victoria map in a picture editing software. There you will see clearly which parts of her body that is to be found on which map.
