Painter 3d came with my copy of Poser 4. That was when metacreations owned both. I have tried to use it and did not like it all. If I were you I would stick with UVmapper and Photoshop. If you want to spend some money hold off and buy UVmapper Pro. According to the UVmapper site its due out shortly and its going to be really awesome. For that matter UVmapper is awesome. The longer I use it the cooler I realize it is. Just my opinion for what ever its worth.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
I have used P3D to define mapping: where front and back match up, what is where on the face, etc. It seems to have all of the difficulties that come with learning Painter 6/7 without much of the real function. It does allow you to get right at a location, but the flaw in the program that produces a streak when you cross a seam is a major irritation.
If you can get it "on the cheap" then go for it. The full version of Painter3D (notSE) is a very good painting program in it's own right & is similar in function to Painter 5.0. It includes layers (floaters) which are great to paint on & "nudge" into position on your model. Also has a great variety of paper textures (rice paper, crackles, pavement, eggshell etc.) which make for nice bump maps. Terrific amount of art brushes, filters, image hose nozzels etc. There is a steep learning curve to it as there are so many options. Also, it is much easier to create your base texture map in UVMapper & use that to apply as an "existing" texture map to your imported model instead of trying to create it within Painter. The problem with UVWrapping (as Jaager pointed out) can be solved by creating masked selections to paint within. That way you won't paint over a hand that may lay between the front & back of the torso. Or, you could create a seperate layer for each "front & back" for each part & and paint upon that layer. I.E., make a new layer with just the front & back for the head only etc.
I have a chance to purchase a new copy of Painter 3D for a good price and was wondering if anyone out there is using it with Poser and other applications. I recently downloaded UV Mapper thinking that it would be a simpler way to make my own textures in Photoshop than buying a new application. Any thoughts?
