Thu, Feb 6, 9:41 PM CST
Subject: Exporting an object in Bryce 5
eagroop ( ) posted Wed, 28 November 2001 at 3:58 PM · edited Thu, 06 February 2025 at 9:29 PM
I recently upgraded from Bryce 2.1 to Bryce 5, wow!
Hating to sound like a newbie but I am unable to export 3d objects ( 3ds, dxf, obj ect).
When I have an object I've created or modified ( which I have highlighted ). The "export object" option under file is is grayed out. Im sure there's a simple reason for this but for the moment Im stumped.
Also when exporting a 3d object with a negative boolean intersecting a postive will both ojects be exported? I would like to have just the positive object.
Thank you
VirtualSite ( ) posted Wed, 28 November 2001 at 4:26 PM
The only thing Bryce will export right now are terrains. Objects made with primitives don't export.
eagroop ( ) posted Wed, 28 November 2001 at 6:53 PM
Thanks, I was excited when I read in the manual that this was possible. Does anyone know if they plan to implement this in a patch in the future.
deadboy ( ) posted Fri, 30 November 2001 at 11:54 AM
I find bryce to be painfully slow at rendering So can I import an object, apply a surface, save the object and then render it with the surface intact in another app?
