Sun, Dec 1, 10:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 01 9:20 pm)
Subject: Problems.........................
Kuruption ( ) posted Sat, 01 December 2001 at 9:22 PM ยท edited Sun, 01 December 2024 at 10:22 PM
I've downloaded a few items of clothing from ISOP's Page and when I try loading a piece of clothing it either tells me it cannot find .OBJ or .CR2 File. I've place the files in the right place and it still won't load can n e one help.
rodpanther ( ) posted Sat, 01 December 2001 at 9:52 PM
usually the objs are placed in a folder called iso in geometries (Its Case specific so make sure its iso and not ISO or Iso or any other varient) The character or cr2 file should really matter where it goes in the charcters dir in runtime. What to do is make sure you have unzipped it correctly. Then load the model, if it asks for the obj file, click on start button, then find files and locate where the file is on your hd, if it is not in the folder that poser asks for then just copy it from the folder it is and paste it in the correct folder. If you maybe say what model you downloaded so i can figure out anything else. I have all of ISO's stuff and have no problems with any of them, except the yori armour but that was just a texture thing that was solved by locating it and loading it in.
Kuruption ( ) posted Sat, 01 December 2001 at 10:13 PM
I've Downloaded Wakana, P-spec, Cami Mircro and the lingerie and none of them work. Another Clothing that doesn't work is the Cheongsam.
shadowcat ( ) posted Sun, 02 December 2001 at 12:44 AM
I'd say double check the folder structure, you might have duplicates example: (runtime/geometries/iso/runtime/geometries/iso/file.obj)
Kalypso ( ) posted Sun, 02 December 2001 at 1:18 AM
Site Admin
I find that most of ISO's latest stuff is made on Pro Pack which means the .obj is stored with the cr2 in your characters library. Unzip and be sure to copy the entire folder with its content in your characters library making sure you have no subfolders inside. The naming of the folder is essential, keep it as it is given, do not rename as this will cause problems. If it's an older item and .obj is stored in the Geometry folder then the read me will say so. Check the file placement again because they all work for me and I use most of his stuff regularly.
Huolong ( ) posted Sun, 02 December 2001 at 9:56 AM
There are some problems with some Japanese models in that some referenced file doesn't have a romaji equivalent that non-Japanese operating systems can read. I've downloaded the above files and they work fine, but I have PPP.
Gordon
igohigh ( ) posted Sun, 02 December 2001 at 10:42 AM
I have all the above too (with No PPP) and they all loaded, BUT I have had many (can't remember if any were these) were the actuall CR2 had a different 'case' in the spelling then the read-me states and even some that claim to 'auto unzipp to correct folders'. Open up the CR2 in a text editor (I use NoteTabPro and Programer's Text Editor) and compair the actual file to where the *.OBJ is loacated. DOUBLE Check spelling too, I have found some authors misspelling their own names or changing the 'case' from one post to another post and event the spelling of the *.OBJ itself!!!
Kuruption ( ) posted Sun, 02 December 2001 at 11:46 AM
Thanks 4 the tips I see if I can fix it and get back 2 u
