Mon, Jan 27, 12:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Head morphs from Vickie on Daz Girls
Kayleb ( ) posted Mon, 03 December 2001 at 11:31 AM ยท edited Sun, 12 January 2025 at 11:44 PM
Trying to use some of the Vickie head morphs on the Daz preteen girl but they stretch her neck and it can't be adjusted by scaling. Can the morph file be hacked to correct the problem, and if so how?
Staby ( ) posted Mon, 03 December 2001 at 1:39 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=373524
I could never explain it better than Anton did, so here is the link to his post... Hope this help.
Kayleb ( ) posted Mon, 03 December 2001 at 1:56 PM
Exelent, thanks for the help!
wyrwulf ( ) posted Mon, 03 December 2001 at 2:13 PM
You can also transfer morphs from one Cr2 to another with Morph Manager. I haven't tried loading an OBJ morph yet, though.
Jaager ( ) posted Mon, 03 December 2001 at 2:59 PM
It is best to avoid Poser 4 altogether when getting the Victoria morphs into a Milgirls CR2 and as wyrwulf says, use MM4 and transfer the deltas (or cut-n-paste the deltas with EditPad). They do not contain absolute position data and the OBJ does. Any V1/V2 morph will copy to the girls. This does not mean that it will produce a usable result. The bodies are already morphed and the sum is unpredictable.
Kayleb ( ) posted Mon, 03 December 2001 at 3:31 PM
I found that transfering body morphs as you say has unpredictable results so I loaded in vickie then double clicked on the daz preteen and kept the transformers etc. with good results for most. I tried to load the head morphs with the results of stretched necks. I will try the cut and paste with the deltas, should do the trick. Thanks
