Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
I'll try and help, hopefully I wont make this too rambley. When you load a new texture, it pops up at the top of the list at that moment, and SkinHead (using naked Vicky as my example) is the first Material option in the drop down menu, so what you do is go through your Texture Map drop down menu and find the texture for your characters head and restore it. Then on the drop down Material Menu locate Eyewhites,Eyeballs,Pupil,Iris etc and in the Texture Map drop down for each one select your chosen eye texture map. It also sounds like your 'Texture changes apply to entire figure' box may be ticked on, make sure that is off, because that also causes the eye texture to go everywhere. I hope that wasn't too mottled. I'll double check the manual and hopefully put it more articulately.
i downloaded the fantasy eyeball textures & was wonderin how to make the eyes of the poser model work w/the fantasy eyeball textures. i selected the eyeball of the model loaded one of the textures & all it did was color the model & not the eyes. am i missin somethin here? please help. thanx
