If you select your prop, and then hit E over on the tool bar, when the window pops up, hit CTR-D and you'll get an export box. (Assuming you have the obj import/export plug-in by Habware...the link is in free-stuff/Utilities) It's a real mystery why you can't do it from the file menu. Some objects this will not work, as there is no E option on the tool bar. don't know if there's a way around that or not. I've had to invert normals in uvmapper in order to get bryce exported objects to take a texture map...in case that comes up for you also. Hope that helped, I'm kinda dumb so it's nice when I can answer a question. :) -Darth
Hello, i am new to the forum so please bear with me if this question has been answered... I am wondering if it's possible to create poser props in bryce4. I cant seem to export, for instance, a sword that i've made. If not...what software is recommended for creating poser props? Thanks
