Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
The head and maybe the hands and feet are the same between Victoria and Vicki P4. The morphs "should" transfer with Morph Manager. The reason they don't work applying in Poser is that the head is in a different position between the two. Morph Manager just reads the "deltas" of the morph. You might have to add the morph to an original Victoria in Poser, save the figure, then transfer the morph with Morph Manager. You can transfer Victoria morphs to the Mil Kids the same way.
I thought she was talking about her navel morphs, because I believe all the head morphs are already in the standard Vicki P4. Keep in mind what I'm about say is just a theory. Both Vicki2 and Vicki P4 share the same mesh, they only differ in size and how they are split. This is how you might go about transferring Vicki Morphs: 1) Zero pose and position Vicki 2 2) Set the desired morph(s) in Vicki 2 3) Scale Vicki 2 to match Vicki P4 4) Export the complete Vicki 2 as an object file 5) Import the Vicki 2 object file (it should be one piece) 6) Using the grouping tool to spawn prop to match Vicki P4 groups 7) Export spawn props as object files 8) Use object files as morph targets You don't have to use the whole figure; in the case of your navel morph, perhaps all you need to do is the abdomen. Downside - your resizing and reshaping of Vicki to match Vicki P4 must be dead on, close isn't good enough. The regrouping must match Vick P4 exactly, one ploy more or less and it won't work. This would be much eazier for DAZ to have done. If you have the money, get Posette Peeks, it's supposed to work with Vicki P4.
I use the P4 version of Victoria more than I use Victoria2, mainly because of the large collection of conforming clothing that I have for P4Fem. However, I've discovered that morphs for Victoria will not work on the P4 version and body morphs for P4Fem will not work on the P4 version of Victoria2. Could we have a little support for this character, specifically in light of the anticipated P4 Version of Michael coming? Liz Pope Dreamspinner Inc.
