Sun, Jan 12, 9:28 AM CST
Subject: Plant creature probiscus extended, per request.
davo ( ) posted Thu, 16 December 1999 at 12:15 AM ยท edited Sun, 12 January 2025 at 7:48 AM
Here is my new plant creature with it's probiscus exteded fully. The probiscus is a seperate poser file with the bulb set as parent, that way you can turn off some of the segments to make it shorter. I plan on making a tentacle/probiscus pack that would be used as add-ons to my creatures so you can mix 'n' match,(comming soon hopefully). Davo
Anton_Kisiel ( ) posted Thu, 16 December 1999 at 12:54 AM
Really good. The texture really compliments the organic mesh. Very cool. Anton
LoboUK ( ) posted Thu, 16 December 1999 at 5:46 AM
Oooooo, Mix 'n' Match critters, now there's a damn good idea. Paul
davo ( ) posted Thu, 16 December 1999 at 9:13 AM
Thanks for the comments. Mix'n'match, I've been kicking that idea around for a while. The only problem is you have to set parent/child relations and you dont get bending effects. I could supply the parts and let people put them together then save a new figure. As for the texture, it's nothing more than cylindrical UV applied to the entire creature then a small mottled tiff is applied and the figures color adjusted with the color tool. If you guys want to do different stuff, then you'll have to use a mapping program and do your own. Davo
