Couple of things I would try if I encountered this problem; Try running scandisk/error checking on the drive you have poser installed on. (had acorrupted entry in my textures folder that choked Poser every time until I found it, once) Try disabling hardware acceleration. Try changing screen resolution to another & back again. Check & see if there's an update for your video driver (Saw something similar when a VidDriver file went corrupted on a PC) Try a "clean install" of poser on a different drive (if you have one) or under a different folder if you don't. (if it starts okay, restore your Runtime folders one at a time untilPoser no longer starts to see if one of them is causing the problem.) Each thing you try, check poser after, & if no improvement reset back any changes before you try another.
Probably have to do the above described torture... but before you do, (I tried to imagine a way to force the display to look that way) make sure the display is not in Silhouette mode with Box Tracking on. (I know, - doesn't explain how it would get that way after a fresh reinstall, or, account for the lockups on renders)
I get this kind of error when I rendered a few scenes with large (3000x3000 plus) tuxtures and bumpmaps. The PC runs low on resources, which it cannot reclaim. Nothing else to do than saving your work a.s.a.p. and reboot. Dont rely on RamBooster or other memory cleanup programs, they will mess up memory management. Maxx
BTW, I dont think its a Poser problem, but more likely a Video card Driver/OpenGL DLL library/DirectX (come with Windows) problem. For all I know, Poser utilizes OpenGL as a few other graphical programs, e.g. MorphMaster. Older OpenGL libs are quite buggy. Esp. when Poser, Morphmaster and Anim8tor are ran together. When one of them crashes for one reason or another, you can count on the others following soon. I really think that reinstalling Poser wont resolve the problem, despite the memory problems with large textures its quite stable, check your DirectX settings with DXDIAG residing in C:Program Filesdirectxsetup. I dont know of a standard way to check OpenGL settings. Also use your video cards diag/settings tools to check your graphics. Ill check my HD for some tools for OpenGL, let me know if you (or anyone else) want to have them... Good luck Maxx
Tried the scan disk, installing to new HD. Nothing works. I didn't install upgrades. Figured there wasn't much point. My version is 4.03. Just ran the directX dignostic. Seems to be fine. Vue works and Zbrush also works without problems. Thanks, guys. Guess I can hope Curious comes up with something.
It happened last night, Sharon (Friday) Far as I know I didn't do anything different than normal. I remember opening it, it was fine. I minimized and did something (can't remember what. But nothing out of the ordinary) Brought it back and it was like that. I too have seen it look something like this when looking for a stray material, but always cleared up. Again, reinstalling it should clear up anything like that. I would think it was a hardware problem if I had problems with my other stuff that I run with opengl. I don't get it. Something stuck way down deep in my Operating system maybe? Running windows 2000 pro. It sees Poser and says no way?
I figured I had it licked. I deleted it again. Removed directory, then went into registery and deleted every mention of poser, and Curious labs. I thought for sure that would do the trick.... It didn't. Why me? Misery loves company, be nice to know I'm not the only one... guess I am. Lucky me. I give up.
I have the same problem - too much virtual ram - your page file size greater than 3 gb and poser freaks - every time or two I render a large scene, I have to increase the page file / virtual size to get a render without running out of disk space (which is what poser says when it gets lost and can't see all the ram and page file even though it is not using all of it) - after I go above 3 gb virtual / page file size, reloading poser gives exactly what you are seeing - if I don't reload poser, it will go on up to 4.095 which is where Win 2000 tops out - if I drop the page file size (go to settings, control panel, system, advanced, performance, etc and reset to below 3000) and reboot to have it take effect - the problem goes away - quirky but can be worked around - I got into this recently when I bought a new high-end computer - I am trying to get poser to fix the bug but haven't got them to yet - Ted
