I lost power on a 65m scene and had the same problem. I was unable to resolve it with Bryce. Fortunately, I had a backup of the file on another drive. Didn't need to use it though because Win ME picked up another problem after an hour of messing with Bryce and set my system restore, which brought back the file. Odd thing is that the 65m file, while it was crashing Bryce after the power failure, was reporting as 0 megs in the file manager. If your file is reporting 0 size, then its gone and you'll have to find another way to restore it. Look in the Bryce temp file and see if there's a backup there.
Sad fact is that happens to all of us at least once. After learning the lesson, ive been know to have 10 files of the same pic saving every few hours and up to 400 megs on the last one. Recovered that particular pic with only 2 hours wasted when something similiar happened to me. Of course burn all your artwork once finished to cdr, because something will eventually happen and fry your entire harddrive collection.
If you have the disk space you could work this way. Do a few changes, save a numbered version. Bryce is smart enough to add a version number when you do a save as. If Bryce goes south, you have a previous version to work from, so you don't have to start from scratch. This is good also if while working on the picture it went down the wrong path and you want to return to a certain point.
Schurby
