Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 2:02 am)
Time to start fiddling with joint settings and scaling. First try scaling up the area that pushed through. Lookin at this I'd try XScale 102% on the hips of the chain mesh. You may need to change the sacling on the rThigh too. You can also try increasin the, um lessee I think its right posative Bulge for the rThigh. If you'll be using this figure combination a lot you may want to build a clothing figure out of the two OBJ files. Somebody did a tutorial in this.
No plans to use this figure combo past trying to figure out how to keep their clothes on them. :) I was just tampering around last night to keep my mind off current events. I'm most of the way through but not all the way through the manual right now. Thanks for the ideas. I'll see if I can get anything to work from that list and if I do I'll make a mental note to remember the technique.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
I think you SHOULD make the figure's hips invisible--that'll teach your figure a thing or two. Make her stand around with Nerd's chainmail briefs just hanging in mid air. You gotta teach these models who's boss if you're ever going to master the program. I'd also suggest downloading some of the discipline props at Nitrane's VAE site to make them behave. The best advice I can give someone who has a problem with the Posettes defiantly popping out of their clothes is this: Render softly but carry a BIG stick.
Nitrane's VAE site? :) Humor or is there a Poser site I haven't found yet?
Renderosity
Gallery
Renderosity Gallery
