Sat, Feb 8, 11:46 AM CST
Forum Moderators: Staff
Subject: How much ram do i need to run Vicki?
VashTheWicked ( ) posted Sat, 15 December 2001 at 5:08 PM · edited Thu, 06 February 2025 at 6:58 AM
Hi, I'm new here and I have the vivki model but every time i try and open it it says cant open obj, followed by not enough memory...i have 256 system mem on a 1 gig system and a geforce 2 card...how much more do i need? :(
ScottA ( ) posted Sat, 15 December 2001 at 5:42 PM
That isn't really a low memory error. The programmers didn't use the proper wording for that error. What it means is Poser can't find the .obj file it's looking for that's listed in the figure's .cr2 file. Make sure the .obj file is in the proper folder and located properly in the Poser folder structure. ScottA
Ajax ( ) posted Sun, 16 December 2001 at 4:48 PM
You could also have a corrupted rsr resource file. Look in the folder where Vicky's obj is located. You'll find a file with the same name as the obj but the extension "rsr". Delete it. Poser will make a new one next time you try to use the figure.
