Wed, Feb 26, 4:20 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: Removing characters from library?
mlofrano ( ) posted Sun, 30 December 2001 at 2:44 PM · edited Tue, 25 February 2025 at 10:52 PM
Hi, I am trying to reclaim some disk space and I was thinking about moving some of the characters and props I never use onto a CD and delete them form the hard drive. My question is, What do I have to be careful of in terms of not leaving anything behind? Let's say I wanted to remove a character. I'm pretty sure I have to delete the geometry but what else do I have to delete or move? What about a prop? I know this might be an elemetary question for some but frankly it is a difficult one for me. I would appreciate any help. Thanks so much.
scifiguy ( ) posted Sun, 30 December 2001 at 6:51 PM
To remove everything, you'd need to get: 1. The obj and rsr file from Geometries (note that not all props have files in Geometries). 2. The cr2 (pp2, etc) and rsr/png from the library folder. 3. Any textures used by the item from your textures folder. If you delete an item from the library from inside Poser, you only get #2. Figuring out #1 and #3 may require you you to browse through the cr2 file with a text editor to see which files are referenced. You can read it with wordpad (if you have windows) or any plain text editor.
mlofrano ( ) posted Sun, 30 December 2001 at 9:20 PM
Thanks you Sci-fi. I think I understand what to do. 3, 2, 1-- liftoff. Project "reclaim disk space" underway.
