Sat, Jan 11, 6:01 AM CST
Subject: Happy New Year ! Help ?
Morzog ( ) posted Wed, 02 January 2002 at 12:17 AM ยท edited Sat, 11 January 2025 at 5:43 AM
What a way to start the new year. This has been mt first day wandering through Posertown, and I must say I am impressed. But like any good newb I need Some help.1/ No matter which style I have selected,wireframe,outline,etc. it always renders in smoothshaded style.My problem is I would like to save these other styles at 800 x 600 but I can only resize with the render ? 2/ When I select outline or wireframe it comes out pink I tried changing the color but to no avail. Any help would be greatly appreciated. Again Happy New Year to all See ya around Posertown.
wyrwulf ( ) posted Wed, 02 January 2002 at 12:26 AM
You can either use menurenderantiaias document and export the image or render a one frame animation using display settings. You can get a bigger render using the one frame animation. Some of the display settings use the material color and some use the foreground color.
hauksdottir ( ) posted Wed, 02 January 2002 at 8:19 AM
Also, under the menu, you can find render options. This includes a switch between rendering as displayed or as normal. If your display is set to wireframe, you get a wireframe render. (You may wish to make the eyeballs and teeth invisible.)
wyrwulf ( ) posted Wed, 02 January 2002 at 9:25 AM
hauksdottir, where is the switch you are talking about? Can you show a screen capture? Thanks.
melanie ( ) posted Wed, 02 January 2002 at 11:42 AM
Hauksdottir, I've been using Poser since version 2, and I've never seen this. Are you using 4.03 or ProPack? I don't have ProPack. Melanie
melanie ( ) posted Wed, 02 January 2002 at 11:43 AM
BTW, Morzog, welcome to Poser! :) Melanie
Morzog ( ) posted Thu, 03 January 2002 at 2:45 AM
Wow guys thanks for the help. Just a couple of things. Wyrwulf, could you please explain how to render a one frame animation ? Hauksdottir, I can't find the switch you're talking about, maybe you could give us a screen capture?
wyrwulf ( ) posted Thu, 03 January 2002 at 9:49 AM
Pages 210 and 264 in the Poser 4 manual explain it fairly well. Also, look at this message. http://www.renderosity.com/messages.ez?Form.ShowMessage=271546
hauksdottir ( ) posted Thu, 03 January 2002 at 10:34 PM
Go to animation > make movie. Under quality, you can switch between render and display settings. (It is actually a pull-down menu, not a toggle, like in a game. I was using switch for the action, not the device.) You want sequence type "image files". ... Darn it! The cat is playing with the optical mouse on the Mac, and I can't type and keep her distracted at the same time. ... Save as "tiff": this gives you an alpha channel. In your image, make sure that you only have 1 frame of 1 (delete the extra frames). It will render quickly in wireframe mode, and save automatically by whatever name you choose.
wyrwulf ( ) posted Thu, 03 January 2002 at 11:21 PM
OK. The same thing I was talking about. The way you described it, I thought it was something else.
