The zip file should extract all of the files in the correct directories under the runtime directory. All I did when I installed is extract the files to a temporary directory and copy the "Runtime" directory to my Poser directory. You can probably (sp?) extract the files directly to your Poser directory, but I prefer to play it safe. Hope this helps!
Is there a simple explanation as to how to install Voluptuous Vicki? I just got it and the instructions in the zip file basically say to install each file by hand to their respective folders, but I'm having a hard time following these instructions. Can't I just extract all the files to the Poser 4 folder, or won't this work? Any suggestions would be greatly appreciated. Thanks.
