Sat, Jan 11, 12:33 AM CST
Subject: Optimal rendering settings for Bryce5
Kagato98 ( ) posted Tue, 01 January 2002 at 8:40 PM · edited Thu, 28 November 2024 at 1:34 PM
Bryce5 has some pretty cool rendering options. For those who don't know, press the little arrow that's to the right of the render button and go to Render Options. Now obviously Bryce5's default render settings aren't too good for many things. The shadows are too hard, it has no bluring etc. My question too all of you is what are the optimal settings for rendering? Should our Optimization be set to aggresive? How many rays per pixel? Should 48-bit dithering be turned on? What should maximum ray depth be? Sorry for so many questions ^_^ . I'm just curious on how to get realistic/good looking scenes in Bryce. Thanks for your help.
Stephen Ray ( ) posted Tue, 01 January 2002 at 10:43 PM
The Minimal, Normal, Aggressive, optimizations are used depending how many objects are used in the scene, few objects = Minimal, lots and lots of objects = Aggressive. This basically doesn't change the quality of the render, but helps speed it up. Ray's per pixel helps with the quality of the render, it determines how many rays are sent into every pixel in the ray tracing process. More rays= longer render times. I seldom go over 64 even with large resolution images. 48 bit dithering helps smooth out any color layering, like you can get with moon rings. Where you can actually see the color change from one pixel to the next, instead of it being blurred together. This image is a good example where 48 bit dithering needed to be used. http://stevesartgallery.bryce-alive.net/gallery8/wolfnight/pic19.html Maximum ray depth determines how many transparent or refection will be penetrated in the ray trace process. Like if you were to place two mirrors angled so they reflected into one another. How many times would you want the reflections to go from one mirror to the other. Or if you where to stack 15 transparent objects on top of one another, you would need the ray depth set to 15, for the last object to be penetrated by the rays.
Stephen Ray
Kagato98 ( ) posted Wed, 02 January 2002 at 9:02 PM
Thanks for the explanations, good buddie. I appreciate it.
