Sun, Feb 2, 7:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: the neighbourhood noob back with a question of poser software (view window)
sir_pyke ( ) posted Mon, 14 January 2002 at 5:33 PM ยท edited Sun, 02 February 2025 at 6:41 PM
well i screwed up many things on my computer and poser is no acception...my viewing window is TOOO BIG!!! how in the world to i set the window back to size in the center of the screen instead of the stupid top left hand corner!! i cant reach dials or anything!!!
bloodsong ( ) posted Mon, 14 January 2002 at 5:38 PM
heyas; if you saved a ui dot, and can find/reach your ui dots, click on them. if not, you'll need to go to the prefs and tell it to start in the factory state, not your preferred state, and restart. if THAT doesn't work, you can edit the poser config file... but i don't recall exactly what to edit. there was a recent message about it, though :/
ronknights ( ) posted Mon, 14 January 2002 at 8:40 PM
Gee, it's easy to set the view window. There are 2 ways to do it. If it's just the view window you want to change, do this: 1.) Click on Windows 2.) Click Document Window Size 3.) Set the size.
ronknights ( ) posted Mon, 14 January 2002 at 8:42 PM
If things might be messed up or you just want to get Poser back to factory settings. 1.) Click Edit, General Preferences.
ronknights ( ) posted Mon, 14 January 2002 at 8:44 PM
2.) Choose the Factory State Options on both sides. Note you can use this method to set your own desired way of running Poser. For instance, I choose not to have any figures loaded in Poser when I first run the program, or start a new document. In that case, you'd be using options that say Preferred State.
sir_pyke ( ) posted Mon, 14 January 2002 at 8:55 PM
thank you both!! it worked..thing is you have to restart your program...oh well..IT STILL WORKED!!
ronknights ( ) posted Mon, 14 January 2002 at 9:32 PM
OH, sometimes we forget some details, grin. I'm glad we could help!!! Here are some tips in case you just can't seem to get a handle on things. 1.) Don't panic. 2.) When in doubt, save your work if you can, then exit the program. 3.) Rerun the program, and see if things work right. 4.) If that doesn't work, then close the program gracefully if possible. 5.) Restart the computer. 6.) Try again. From my experience sometimes our computers just get messed up. One of the first cures for any such problems is to restart. I always say "it cleans out the cobwebs." You'd be amazed just how well restarts work!
