Forum Moderators: RedPhantom
heya; if you have anti-aliasing, the mask poser renders might be a tad 'loose' and cause white lines. i has this problem in ray dream renders til i turned that off. i dont think poser does that, though. if it DOES, 'shop has something under the layers menu called 'remove white matte,' 'remove black matte,' and 'defringe,' which will help you automatically eliminate the weird edges.
You are right using the alpha channel does eliminate the need for the magic brush stage. But I've found that a lot of times I feel the alpha channel edge is too hard against what I am pasting onto. By contracting into the selected area then feathering out, images lay down on to my backgrounds better. jje
But--glad this thread came about anyhow. I had vaguely remembered Allie talking about saving as .tifs and selecting from alpha channel in PS and PSP, but it had sort of slipped over my head. I've now tried it and its a real timesaver, so even if this was a thread not meant to be--I learned something from it S. Diane B
JIM BURTON mentioned a few posts back about getting white edges round your images. Here's how to get rid of that using Photoshop. [BEFOREHAND: Render your poser figure against the standard grey background or some other solid color that you will key against] In P'Shop 1) Use the Magec wand and select all of the background. Start with a tolerance setting of 10 and increase it as necessary. Zoom into your edges and make sure you are getting all the "edge bumpies" 2) under the SELECT MENU: Invert the selection. 3) under the SELECT MENU:MODIFY:CONTRACT... contract the selection by 1 (2 if your image is really really big) 4) under the SELECT MENU: FEATHER... feather the selection by 1 (2 if your image is really really big) Copy that image and paste it onto the background of your choice. or save the final selection as an alpha for future processing. coolness jje
