Mon, Jan 20, 4:26 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: help! problem with PZ3
lelionx ( ) posted Tue, 15 January 2002 at 8:23 PM ยท edited Mon, 20 January 2025 at 1:19 PM
i had loaded a PZ3 earlier and had no problems with it.i saved another PZ3 to keep the changes i made to the original and shut down to take a break.when i came back to do some more work i loaded the second PZ3 and found the skin texture would not apply.it's showing it's loaded in the drop down menue but will not apply.also it will not render.i went back to the original PZ3 and found the same problem.the prop textures load and apply OK.i also tried to change the skin,no luck.reinstalled poser and patch,no luck.anybody have any ideas?
thgeisel ( ) posted Wed, 16 January 2002 at 12:06 AM
Had some similar problem, but no solution till now.Dont know why it happens, its seems to be some posermystic.
lelionx ( ) posted Wed, 16 January 2002 at 1:12 AM
i think it must be a windows glitch,i restarted my comp and now it seems fine.
ronknights ( ) posted Wed, 16 January 2002 at 4:47 AM
Here are a couple of my "rules" when things don't work right. 1.) If possible, save your work, then quit the program. Then run the program again. 2.) If that doesn't work. Restart the computer. Most often restarting the computer clears the glitches away. If you leave your computer on all day, as I do, you really want to restart the computer a few times a day.
